dinnerplate
Originally I wasn't going to make a thread like this, I don't think there's all too much that makes my build special, but @Enki convinced me. This isn't a full build diary, most of my build is pretty much done, but I'm going be highlighting me going big turbo.
First and foremost, some context on the dinner wagon so far (just the highlights):
So why make a thread at all? Seems pretty cookie cutter, if you ask me. Though I suppose there's not a whole lot that can be done differently at this point, given the age of the Mazdaspeed platform.
First and foremost, this is a sidewinder setup, using a BullBoost sidewinder for a K20/K24. Secondly, I have a TurboSmart TS-1 5862. Now I've emailed a few companies, and as far as I have done my research, nobody has ran a TS-1 on a Mazdaspeed yet. The usual suspects are PT5862s, some Garretts, you get the idea.
So why a sidewinder? Well, I work on my car pretty much daily. When it's not on track it's on the street (save for daily driving, obviously). Turbo behind the engine sucks. Maybe if you put it in the car once and never touch it again, it's whatever, but that is definitely not me. Of course it looks cool, too. As for the TS-1? Well, I wanted to be different. The compressor maps don't look too crazy for a Mazdaspeed, and while I was at LS fest I was able to get hands on with a TS-1 and talk to some guys from TurboSmart. I was content with the conversations about the TS-1s enough to at least give them a chance. Worst comes to worst, I get a PT. So this is an experiment, and if you know me, you know I don't shy away from being experimental with my speed.
TS-1 5862 Compressor Map:
I'm currently waiting on my TS-1 to arrive in the mail (some shipping oopsies occurred). As for my exhaust manifold, here's some images. I bought an MZR flange off of Massive Speed Systems, and will be having a local fabrication shop install the flange in place of the K20/K24 flange (with backpurging, of course). Some supports will be put in the runners as well. Odd how closely K20/K24 flanges have the runners line up with MZRs. That being said, if you don't have the deepest pockets in the world to spend on completely custom fabrication for an exhaust manifold, you will be able to get away with Honda manifolds with replaced flanges. Again, for me this was all an experiment, and you'll be seeing how this goes as I update this thread.
As far as finishing this off things I need:
Alright that's all I've got for now. I'll update later when more work gets done or parts get received, as well as answer any questions you guys might have.
- 08 speed3, sitting on full whiteline suspension and full TB performance bracing and traction bars
- Built engine (Manley platinum extremes, H-Tuffs, Mountune crank, King bearings all around, studded, some other stuff) built by yours truly
- Mishimoto S-line intercooler, converted to gen 2 filter housing with Damond cooler, FoST intake manifold with port injection spacer
- Tuned by Damond
- Split Second Controller and injectors (already have everything else for port injection setup, these two things are the only items I have yet to purchase)
- Clutch
- Oil feed and return lines
- A new hot side intercooler pipe
- Downpipe
- Wire tuck harness
