P0192 please help
Mohammed
Is anyone able to help my issue i have a 2006 mps 6. Recently it has thrown a code p0192. I have changed the fuel pressure sensor with a genuine used one as well as hpfp from another mps working car. It still remained to have that code after clearing the code.
Second step was to check the wiring I checked the wiring and it's showing 5 volts going to the sensor. But the hpfp pigtail was only receiving the 12v the other pin wasn't getting any power. This was the day I changed both the parts. Next day when I turned it on the hpfp was working like nothing had happened.
My mechanic checked the blue clipped hose from the back seats and it was coming out good flow. He even checked the blue clip hose on the hpfp which was good flow. My plugs are pretty bad. And my bypass valve hose going back to the intake was ripped.
I have ordered ngk plugs and aftermarket hose. Before it used to miss fire like crazy when I drove it wouldn't let me go above 2.5k rpm.
Now it lets me go above 3.5k rpm but still bogs down.
ANY HELP WOULD BE MUCH APPRECIATED
