So I installed a dash cam this weekend. Ran wires front to back. Now I can flip the switch and turn em on, but it no longer notices the door is open. Wtf. Any ideas?
I've had this issue for a while now, but its intermittent. Most of the time, only one bulb will light up even thought I've tested it in another car and it works fine. Hopefully someone has a fix
There is the wire that feeds to the door to light the circuit when the door is open. I'd check there first to see if you cut into one of those wires. What did you wire the camera into? Mess with any grounds?
Didn't hard wire but I used fish tape to pull wiring between drivers side front and rear doors. I'll probably drop the headliner tomorrow to take a peek.
