I only remember mixing needed to prevent it.IIRC, 50% or less is the most you can go, and you needed to dump sl1 fuel system cleaner in the tank and HPFP every once in a while.
Incorrect; worst pump I've ever seen was off a pump gas only CX7 and the stock internals (which you can normally just pull out of the pump from the back without taking the retaining nut off) were seized. It was so bad, they couldn't get it unbolted from the part that bolts to the head, so that came with the pump too.I only remember mixing needed to prevent it.
hello and welcome to MSO, searching can yield some wonderful threads, I find it best to use Google "black death site: Mazdaspeeds.org" will filter results to here and yields this thread which is quite helpful and will answer many of your questionsI'm not in the loop on this and I was asksd. 100% E85 in the tank... causes the sticky "black death" locking up the high pressure pump.. doesn't occur if running a gas/eth mix. Was this ever figured out?
Don't worry, you will eventually.... havent touched the pump in 8 years, 30k miles...
I don't think Redline is the cure, I think the Royal Purple Dexos is the cure.
Don't forget, I'm asking for a friend. I'm 93 octane life
Thank you for the spoon feeding!We have a thread for that too... Any of the Total purple oils they're all dexos 1 gen 2 iirc (verify) and pick your correct weight needed
https://mazdaspeeds.org/index.php?threads/best-engine-oil-all-mod-levels.7931/
That one stung.No need to fix the search function @Awafrican does it for you
*Sometimes. I do try to be helpful and give folks the answers but I can't catch everyone. I've got many threads bookmarked for quick links, I should really put them into a useful threads thread like the old place had, sticky it and send it out on the welcome PM.No need to fix the search function @Awafrican does it for you
