10th Gen Civic RaiderFab Bumper Fitment Solution Fenderwell Solution Installation Guide.
What’s In The Kit:
Tools Needed:
Installation Process:
What’s In The Kit:
- 2 Quik Latches
- 2 Latch Pins
- 2 small washers
- 2 larger washers
- 4 nuts
- 2 assist springs
- 2 assist spring retainers
- Threadlocker
Tools Needed:
- Saw or similar cutting tool
- Small flathead screwdriver
- Small phillips screwdriver
- Trim clip tool
- Ratchet
- 10mm socket
- 11mm socket
- 11mm wrench
- Drill
- ¼” drill bit
- Stepped drill bit or ¾” drill bit
- Paint marker or something to mark the bumper
- Remove front bumper
Using the 10mm socket and trim clip tool remove the front bumper.
- Remove bumper brackets
The plastic bumper brackets must be removed and modified. To remove these brackets the single phillips head screw must be removed and then the two plastic tabs must be compressed with a small flathead screwdriver and then the bracket can be removed.
- Modify bumper brackets
- Remount bumper brackets and install ball studs
- Check Quik Latch fitment
- Mark bumper for drilling
- Drill hole in bumper and install the Quik Latch
- Install Assist spring and spring retainer
- Set ball stud height and reinstall bumper cover
