Nactan
I've had my Speed 3 for about 4 years now and it has 155k on it. In the last 8 months it has started having engine problems. To my knowledge, it's mostly stock. It has a Cobb cold air intake, and a cat back exhaust. July of 2021 I replaced the K04 cartridge with a re-manned one and did the VVT actuator at the same time. Last December I replaced the PCV since the engine has started burning over 1qt every 1000 miles and blasted the intake valves. I also upgraded the PVC plate with a Damond plate. Still, it's down on power and burning oil. So that leads me to think the piston/oil rings are bad especially since my compression test results were 150 150 120 150. I haven't done a leak down test though. Initially, I thought replacing the rings wouldn't be terrible but after some reading I'm not so sure now. I'm not looking to make more power or tune. I just want it to run like it used to.
So, my questions.
1. Can I just replace the piston/oil rings with stock equivalents from EdgeAuto and hone the cylinders or do I need to upgrade to 88mm pistons and new rods?
2. Is it possible to pull the pistons without pulling the block or removing the crankshaft?
3. I saw someone mentioned deleting the balance shaft, is that recommended because it has to be removed to pull the crankshaft?
4. Aside from friction washers and gaskets, are there any other parts that must be replaced?
So, my questions.
