Hey guys so as the title states my A/C clutch is not spinning with the pulley. First off let me state the number of things I have already done to diagnose the problem. Of course worst case scenario would be to replace the compressor but I haven't gone that far. So far I have:
1. Replaced A/C line that had a crack and vacuumed system and refilled with refrigerant.
2. Checked all A/C related fuses
3. Replaced the A/C compressor relay
Now after doing all of that I figured I should make sure there is power going to the compressor in the first place. So I hooked up a test light to my battery and verified the ground was good. However it appears there was no power going to the plug attached to the compressor. I also noticed no "clicking" of the relay when I had someone turn the A/C on and off.
Basically I'm thinking this is an electrical issue but I'm stuck as to what to do next as the problem now seems to lie between the power connector and A/C compressor relay.
Please let me know your thoughts about this and if I may have missed something or what other steps I can do to verify the relay is working and if power is going to the compressor plug or not.
Thanks for reading.
Thanks for reading.
