Ben_anderson.ms3
Hello, I have a 2008 speed 3 which I am slowly building while in college. I have some simple mods so far such as hpfp, upgraded tmic, bov, and now an access port. Now here is my issue, I got an access port to of course tune it, but also to help me sort out some of the issues with the car. I loaded one of the crappy 93 tunes on there to just get base readings but to my surprise the access port will only read rpm and coolant temp, that is it. Boost is stuck at -7.0 and wont move at all, afr wont change, nothing will read but those two things. Would anyone happen to know if this is a problem with my access port or is it something with my car like the ecu. I would appreciate any type of insight, and if any additional info is needed, i know quite a bit about the car. Thank you
