So i was just at the pump to throw a little e85 in the tank. I'm on my 93 tune and after the fill-up i went to switch to the e85 tune (i use a 33% mix so this fill-up was 5 gallons e85 and then top off with 93 (8 gallons).
Well as just my luck would have it, my Accessport will no longer talk to the ECU (coms error). I just used it 2 weeks ago to flash the ECU as well as do some monitoring with no issues.
My OBD2 cable has no obvious defects and my Accessport is in good condition.
I drove the car home and popped open the accessport and everything inside looks solid. No corrosion or connection issues.
- Will i be okay driving on this mix or should i siphon everything?
- What could be causing the comms issues? Everything seems good and i was just using it, but obviously failures can happen without warning
