phate
Motorhead
One of the most nebulous topics for the MS6 since it came out was how the AWD system worked. How it transfers power to the rear wheels, how much it can transfer, and when it transfers are mostly unknown to the masses. Let's try to clear some of that up, and let's do some testing to see how much we can really transfer to the rear.
I'll just say it up front - The MS6 can go 100% rear drive.
The general layout of the drivetrain looks like this. As you can see, there's only two points of potential slip in the system.
1) The clutch - operated by your left foot. This effectively becomes direct drive once you engage it.
2) The rear diff coupler - full of black magic.
Note that the PTO/Transfer Case is NOT a place of slip (until it explodes). The tcase is splined directly to the front differential case through a third set of splines:
This is what it looks like with everything pulled from the trans:
Now that you know the transfer case is splined directly to the front diff housing, you should realize that you can remove the front axles entirely, and it could be 100% rear drive. That also means that if you hit an ice patch with just the front wheels (0 traction, let's say), that the rear could get 100% of power being produced if they had traction.
In the next post, we'll talk about the rear diff coupler.
