BATS/Flow Treadstone TR6
Jtotheonah
I am looking to install a Treadstone TR6 on my speed (already have a ‘decent’ front mount on).. I am running stock turbo and seeing about 10- 15 degrees above ambient when cruising and then temps drop to about 5-8 over ambient when I’m boosting. Has anyone ran the TR6 on stock turbo? What were your overall temps like and what was maximum flow you saw on your logs ?
What's a "decent" front mount? Make / model?
As for TR6 hard specs:
Core Size, 6" X 22" X 3.5"
Overall lenght 28"
2.5" inlet/outlet
600 CFM flow rate
400 HP efficient
Less than 2psi pressure drop at max flow
less than 1psi pressure drop
I
Overall lenght 28"
2.5" inlet/outlet
600 CFM flow rate
400 HP efficient
I live in South Africa so the only way to get a bar and plate core with a decent thickness was to buy an Intercooler and have it cut heightwise and welded over with an aluminum plate to fit beneath the crash bar. I know the specs of the TR6 But I am trying to get real world data in regards to temps and flow from people who are running them
I
don't have data on it myself hence the specs on it, was hoping that if you knew data on yours you could compare a little that's all, hard to tell improvements without knowing specs.
As for rest of the data temps etc asked about hopefully someone else chimes in.
I run a TR8 and it fits well in my first gen. In terms of BATs I see almost a 20 degree drop within a second or two of going WOT depending on the conditions. It flows amazing. I cant speak on the TR6 but I assume that with it being slightly smaller it would still perform to your liking.
FWIW I ran a crappy CX intercooler when I first had a front mount setup and after going to a real quality IC I'll never run a cheapo ebay again and that's what I compared the TR8 to.
Tha
Thanks for the feedback man. I'm a college student and have already invested a lot of money into the car so as much as i'de love to get a bigger turbo I think i'm just going to maximize a ko4 setup. It feels like a TR8 is overkill if I'm not upgrading the turbo and I know that bigger isn't always necessarily better because intercoolers can be too large (or small) relative to turbo size
What turbo are you running ?
I was running a BNR S1 and now a BNR S4. You're not gonna see that much of a pressure drop by spending the extra amount and going larger withe the TR8. It also is a little better if you're planning on upgrading the turbo one day. The TR6 will be fine I'm sure but it all depends on your future goals.
Awe shot !
