Why?
Because it moves the pivot point forward. No other RMM does that.
Basically it turned an elbow into a wrist.
Once you see it in action that analogy will make sense.
Hows the cabin noise?- Barely noticeable increase and what you do hear is pleasing not irritating.
No matter how hard you make the rear disc, that “elbow” design is going to allow way more flex and engine movement than this “wrist” design.
Rear gets bolted in with no rubber or poly mount
Front bolt get a horizontal poly mount and bolts through the bottom of the triangle mount.
You can watch the difference between the two in a video on the product page.
Try it before you knock it.
