Bilstein Valing MS3 & MS6
Tomas
In these worksheets you will find the of the shelf Bilstein valvings for both the MS3 and MS6 as well as my attempts to re-valve them for track use.
Re-valving shocks or struts is not something you will ever have a definite answer on. Many variables are at play here. If you are looking for a quick answer on how to set up your suspension you will not find an answer by merely looking at different shim stacks.
