BNR S4 V1 kit stuff
Dedlyvirus
Hey guys. I just picked up a used BNR s4 that I'm going to use to replace my k04. My question is, what comes in the kit when you buy it new? I already purchased all new gaskets, studs, and nuts. I have an EBCS and 3 BAR map sensor already. I read that there are crush washers that come with it, and the picture from edgeautosport.com shows some kind of coolant or oil line. Does anyone know what all I need to pick up before I get in there and realize I don't have everything to swap out turbos?
There are copper crush washers for oil feed line and coolant lines. I think they're 14mm. The kit comes with a pre-bent oil return line, but you can just bend the line from your k04 I would assume. Kinda shitty the person you bought it from didn't include it.
Also you might consider replacing the oil return line gaskets. Some do, some don't.
