Hello,
as mentioned in my introduction I have a boost issue with my Mazdaspeed 3.
Modifications
-2.5 swap including the timing
Replacements
-replaced intake cam to fix P0012
-replaced aftermarket cold-air intake for stock
-repalced old worn turbo with Rockauto GPD k4 turbo
Symptoms
-low boost
--1st/2nd gear 5psi
--3rd/4th/5th gear ~8-10psi
--6th gear full 15psi
-WOT bucks at 5000 RPM in 1st/2nd/3rd will not redline, wont buck when creeping up to redline
-rich in 1st/2nd gear
-O2 and MAF go out of spec near redline
Wierd symptoms- My father got ahold of an Autel scanner and recorded these parameters, hes never uesed them for diagnosis thought.
-Fuel injection amount[mg/cylinder] and engine load is out of spec
Diagnotics
-checked all clamps and hoses
-checked cat for any blockage
-did boost test plugging the intake with a plug and used pressure regulator.
(all this did was inflate the intake piping and all I could hear was the head filling with air. I may need to come back/ find a better way of doing this)
Me and my father, who is an ASE master tech have been trying to hunt this issue down, but hes not familliar with this car or engine. Would love to hear y'alls thoughts on this. I probably need to find a better way of doing the boost test. During the 2.5 swap the pipe leading from the head to the intake got snapped in half. we quickly put hosing over it. This is probably causing un metered air to come into the system. and thats all I could hear leaking when I did the boost test.
thank you.
Modifications
Replacements
Symptoms
-low boost
--1st/2nd gear 5psi
Diagnotics
thank you.
