...barely getting boost. This randomly happen while going aggressive merging on a highway.
ENGINE/DRIVABILITY
Year/Make/Model: 2012 Mazdaspeed 3
Mileage: just over 140k
Concern: see links: https://www.revisionsrus.com/logs/2484 \ https://www.revisionsrus.com/logs/2485 \ https://www.revisionsrus.com/logs/2486
DTC's: P0172 on and off or hidings in the background. P0335 on and off; and randomly getting the fan malfunction code where in traffic, coolant temp will get up to 240. U0140 I had for years. Nothing really tells you what needs to be done to have that code permanently disappear.
Modifications: in my signature
ECU/Tuning Software: Cobb Accessport V3
Tuner: Hypnotic
Is the concern intermittent? Somewhat
Can you duplicate the concern? I have the logs above.
Recent Repairs: injector seals...fuel leak (P0172 was before that)
Correction: visual check to see if any vacuum lines were broken or couplers loosen,cleaned MAF sensor, soapy water test everywhere. I was planning to replace the O2 but I wanted to troubleshoot more to get the P0172 out the way. the fan malfunction...might need to change with module? The P0335 I change the crankshaft position sensor but code goes off and on.
ENGINE/DRIVABILITY
Tuner: Hypnotic
