Bought 2004 MSM formerly used as a gambler 500 car
joeycr
I am new to Miata. I bought this 2004 MSM in the spring this year. The car was heavily used and was modified to be a gambler 500 car. The seller said the head gasket was replaced shortly before I got it. I am not sure the head was machined before that because the head gasket blew on the way home. Also, the head bolts might have been reused a couple of times.
Someone before me had the crank main and rod surfaces machined 0.25mm. The bearings that came out look pretty decent. The cylinder walls look perfect and factory spec.
I got the head completely refurbished and am rebuilding the motor at the moment. Parts are ordered and on the way.
Looks like you have your work cut out for you
Will be fun to tear up shit with once it's running smoothly!
well that's a frustrating drive home to say the least. welcome to mso, hope the rebuild goes well
