Enki
Moderator
I wouldn't run two cans in line like that. If you absolutely had to for some reason, at least get rid of the 2 90s and replace it with a sweeping bent hose (no kinks) as that will help keep velocity and flow high.
Ideally, if you need to use two cans, you should plumb them in parallel.
In any case, your issue might very well have to do with your PCV check valves.
