Hoobrus
In the process of replacing my two front control arms on my 2011 Speed3, I had to remove the bolts that also hold the sway bar brackets on. I then discovered, not too surprisingly, that the sway bar bushings were dried out and cracked. I didn't know I'd even have to touch these, or I would have been ready with replacements, but oh well. I took an emergency trip to Autozone and bought some Moog/Duralast replacements (https://www.autozone.com/suspension...-sway-bar-bracket-bushing-hb200675/278154_0_0), but despite double checking I discovered that they are too small. It looks like this is a common mistake, and most of the online parts finders don't realize that the Mazdaspeed3 is a different diameter. I'm actually having a hard time finding a replacement that I am sure of, other than OEM (B37F-34-156B). Even the Corksport brand claims to only fit the gen 1.
My most urgent question - since changing this requires again removing the two bolts that hold in the rear of the control arm, will this mess with alignment? I had an appointment scheduled for alignment but it might make sense to wait if this is the case, although I'd rather get that done ASAP. If it doesn't affect alignment, I may just put this job off for now and keep my appointment.
