Johan Mall
Hey guys,
I have a gen 1 MS3 and it’s having an issue where it’s not going past 4k RPM’s unless I’m very light on the throttle..
*MOD LIST*
550 HP Capable Built Stage 1 Graveyard Performance Engine
CX Racing Intercooler Kit - Treadstone TR1035
BNRS5 Turbo
BNR S5 Turbo Drain Line
Grimmspeed EBCS
XClutch Clutch Kit - Twin Solid Organic
Tial MVR 44mm External Wastegate
Blue, Black, and Yellow Installed
ATP Dump Tube
JMF V2 Intake Manifold
Graveyard Performance Return Less Port Injection Fuel System
Graveyard Performance Tubular Exhaust Manifold
Graveyard Performance Coilovers - GL Series
Graveyard Performance 3.5" Aluminum Intake
Graveyard Performance Crash Bar
Graveyard Performance Oil Feed Line W/ Billet Filter
Bosch 3.5 Bar TMap Map Sensor with IAT
TurboXS Catless Downpipe
HKS Catback Exhaust
Damond Oil Catch Can Stage 1
All 3 Damond Motor Mounts
Damond EGR Block Off Plate
Damond PCV Plate
Damond Short Shift Plate
JBR Short Shifter
MS6 Slave Cylinder
NGK 1-step colder Spark Plugs Gap .24
I can’t seem to figure it out. I just replaced the throttle body thinking maybe that was it and I recently got new plugs. This build has less than 10k miles on it. I’ve boost leak tested multiple times. When it’s hitting that 4k RPMS, I can hear my turbo spooling, but I’m just not getting any power from it.. any help is greatly
appreciated. Car has been down for a couple months now.
Thanks in advance.
-Johan Mall
*MOD LIST*
BNRS5 Turbo
Grimmspeed EBCS
ATP Dump Tube
HKS Catback Exhaust
Damond PCV Plate
JBR Short Shifter
MS6 Slave Cylinder
Thanks in advance.
-Johan Mall
