installed a new cat less downpipe. reused the oem o2 sensors, got p0134 immediately, AFRs stuck at 14.8. inspected wiring and found no pinched wiring. checked connector and found a spread terminal on the black connector on the female side. fixed it, but still getting 14.8 for AFRs and no change after warm up, as far as I can tell o2 sensor is good. connectors are good. checked bar fuses and both are good. disconnected battery for 30 min. still no change. I've got a new OEM o2 sensor coming, but is there anything else I should look at or test? any help is much appreciated.
