Above is the exhaust that @xfeejayx and I created. The concept
is simple: stock exhaust section with hangers cut and u-bolted to a 2.5" x 24" cherrybomb with a vatozone turn down.
Sounds fantastic, took an afternoon to create and install, and frees up a ton of space near the rear axle.
@xfeejayx attached the cherrybomb to the carrier bearing and added some insulating wrap for good measure.
turn down, directing hot exhaust away from the diff and axle u-joints.
One day, once the handling of racecar is better sorted out, I'll revisit this with a larger flanged cherry bomb (3" x36") and weld on exhaust hangers. In the meantime, this works too well to mess with.
@phate has a stumpy version of this.
