Edit :After almost a month of trying things related to fuel and spark I can safely say that it is not related to any of those things. Sounds valvetrain or cylinder related now and in the middle of the motor if looking directly downwards at the top of the valve cover. Definitely metal touching metal slapping type sound now. Is not slight or quiet and has gotten worse over only about 100 miles of test driving solutions. Don't have the time or the space in life to figure it out so pasta lasagna I suppose.???
It starts and is very slight between 900 and 1100 psi, louder between 1100 and 1300 and goes away entirely at 1400 psi.
Logs check out fine and WOT pulls are clean except for the usual SUB .5 spool up KR. Happens regardless of boost levels and in vacuum. Engine RPM has no effect. Gearing has no impact. No fuel smell. Trims are where they should be so boost/vac/exhaust leaks are maybe unlikely.
I had the high pressure hard line rupture about a month ago and the problem didn't exist after I replaced it but then DID start this week after a full plug swap.
Intuition would say injector failure/leak/etc but I'm not sure since WOT log are clean and show no parameters out of spec.
I haven't recorded it but for reference it sounds almost exactly like a cricket chirping.
Any ideas?
Any ideas?
