Memin
I just did a motor swap on my speed6 and y replace clutch with a LUK clutch set, & Slave cylinder. My problem is that when I initially bleed the system, slave clutch was engaging now two days later it stops engaging. Pedal feel the same as before but when the engine is running I cant find 1,3 and 6 gearand Is not leaks. I bleed the slave with a hand pump like 10 times already and all I see coming out is just a little of brake fluid drops; and no a steady stream like when you bleed brakes is this normal??. I am out of ideas, Help!!!!!
