TorukNeikea
Im having trouble diagnosing this rough idle and poor driveability issue, ive replaced both maf and map sensors, yet these 3 codes persist. The traction control light came on at the same time as these codes which does not make sense to me as they are unrelated. I have looked for chafed or cut wires around the MAF and MAP but have not found anything, ive inspected the pcm connectors incase this is the reason for the random issue, and to my knowledge they look fine. Any ideas?
P0103
P0108
P0098 !
Forgot to mention the third code, these codes came on simultaneously.
For some more backstory.
I was driving the car home from work early in the morning since I forgot to bring something witih me. Temp about 75 degrees F outside. I was in a bit of a hurry so I was in about 7 pounds of boost. I dont like to push the car since it's not properly tuned. And from a 2-3 shift I hear a coupler blow off. Luckily I was already close to home so I limp the car home and take my miata to work instead.
The speed sits for about 3 days until I have time to fix it. Come a saturday morning, I bring the car to work my place which happens to be a garage, via a tow truck. (All my tools are at work) I take the filter and turbo inlet off in order to reinstall the coupler that came unattached. (Coupler that blew off was the inlet to the intercooler)
When I assembled everything back together It would turn on and turn off seconds later. I fixed this issue as well as I noticed I simply installed the MAF tube housing backwards. Idiot. Car finally ran great up until 2 days later. Where now I get these 3 codes and my traction control light illuminates. I bought the car an Accessport hoping that maybe it just needed a tune, as the previous owner had an AP, just unmarried it and left the mount behind.
Year/Make/Model: 2013 Mazdaspeed 3
Mileage: 70204
Concern: Car has an inconsistent rough idle, afr hovers @ 9:1 - 10:1, reaks of fuel
DTC's: P0103, P0108, P0098 and traction control light on
Modifications: CS front mount intercooler, HPFP Internals, CS Turbo Inlet and Air filter, MS3 Gen 2 catback. (Those are the mods it has to my knowledge, i bought the car from a california dealer and unknowingly came modified.
ECU/Tuning Software: Cobb AP V3
Tuner: Car is on an OTS tune Stage 1+ SF 93v
Is the concern intermittent? Yes, all the time
Can you duplicate the concern? Yes, letting the car run normally
Recent Repairs: NGK Irdidium Pregapped 0.026 spark plugs from CS, MAF sensor from oreillys, 3.5 bar CS Map sensor
Correction:
P0103
P0108
P0098 !
Mileage: 70204
Correction:
