Ionut
I'm trying to identify the source of this buzzing sound.
Setup:
-Gen2 gearbox rebuilt and fitted with a Quaife lsd. Fitted on my gen 1.
-Rey's cables.
-CS stage 2 rmm. Hardrace (OEM+, full rubber) side mounts.
It shifts perfectly, works well, no problem. Oil is fresh - Motorsport CRX LS 75w90 NT+.
(Before I had usual gen 1 gearbox, OEM cables, same CS stage 2 rmm, OEM side mounts, no buzz)
There's this constant light metalling buzzing sound (like a faint metal cutter/saw), higher the speed of the vehicle the more clear/distinguishable it gets. Doesn't matter if it's in gear or not, clutch depressed or not. It's different imo (higher pitch, constant) from the typical gearbox whine, which I'm used to and was present also with the old gearbox since changing the rmm.
The ONLY time it goes away almost completely is when I move the shifter right (left hand drive car - like going to change into 5th or 6th) and keep it there pressed but not engaging. Which I find odd and because of that I tend to dismiss other possibilities aside from transmission related, but in truth I have no idea.
(Later edit, after careful listening sound subsides when moving the shifter both right and left, although left it the attenuation is less)
Made some clips (attached) but it can be easy to miss, the buzz being a constant thing along the normal rolling sound:
Tried to catch it in neutral and every time the image shifts to the right I move the shifter (had phone in hand) and like 70% of the buzz goes away (muffled).
Any ideas would be much appreciated.
Many thanks
Setup:
-Rey's cables.
Many thanks
