Crackle and Pop tunes released
steve@versatune
We have published crackle and pop tunes for MS3, MS6, and NC MX-5,
This is my Gen2 daily with a crackle and pop tune on it.
As always, you can order at https://www.versatuner.com
Just threw this tune on my car sounds great, curious if this will damage the cat/cats over time? i have a cobb downpipe with high flow cat
Probably. Your MPG is gonna go down at the very least.
Do you have to command the burbles at all or just completely let off. Im running cobb high flow downpipe to a unknown brand catback with one res and muffler. Kinda quiet.
I just floor the fuck outta my car and after shift I get cool boosty pops shifting through the gears! Off throttle pops happen when I decelerate when when not up to temp. Bitch runs rich. Granted these are at separate times.
How would we go about implementing this into a custom tune? I tried the "disable fuel cut on decel" checkbox under options and reflashed, but nothing changed.
You have to mess with the timing and VE tables too. Best bet is to just apply your current tune changes (tables) to the crackle OTS or look at whats different between the two tunes. The changes should stand out.
found a sweet spot
As above this would be far better with the ability to turn on or off on any tune like an option similar to megaspool or 2-step
I was able to compare the stock tune and and the 93oct crackle tune and very easily see the differences. The option for disabling decel fuel cut must be checked as well as some low load changes in two of the ignition tables and the ve table. It's pretty easy to see if you comapre those two tunes. Just copied the relevant values over to my tune and flashed and it worked.
If you could maybe do a guide for some of us less knowledgeable with editing tunes would make for very useful content for a lot of members ?
Some drive by vids
1st gear
2nd gear
Sounds awesome Steve, not overkill but a nice medium just need to be able to add this to my custom map
HEY GUYS I GOT A MAZDASPEED G1 2007 I WHOULD LIKE TO KNOW WHAT I NEED FOR THIS TUNE I JUST A RESZ DELET EVRYTHING STK
