CX axle replace without disconnecting LBJs?
jsilva
Is it possible to replace the front cv axles without pulling out the lower ball joints?
When I did it before I really disliked doing that :) I thought I remembered reading where someone said you could if you disconnect the upper ball joint and angle the assembly outward, but I’m not sure if I’m remembering correctly.
I’ll be doing the passenger (right) side.
