Car description in my signature.
I bought my car new and have 135k miles on it now. On a road trip this weekend it started smoking pretty darn bad after about 6 hours at ~73MPH. It runs fine, the oil in the crank case does not seem low, no check engine light. Here is what I am seeing (took this video tonight after all my troubleshooting, then went for a spin to get it up to temp).
Next I pulled the spark plugs (about 20K miles on Denso ITV22's) and they all look dry. Here is #3's plug but they all look the same.
Did a compression check, all 4 cylinders were 175-180 psi.
Next I pulled opened up my exhaust where the Test pipe meets the cat back and felt inside. It is very carbon'ey but no wet oil in there.
I am assuming this is all pointing toward the oil seal on my turbo has started to fail and is sending oil into the exhaust? Could it be my PCV Valve? I assume if my PCV valve were bad, I would get a CEL, no?
Template public:_media_site_embed_googledrive not found. Try rebuilding or reinstalling the s9e/MediaSites add-on.
Today I started troubleshooting. I pulled the intercooler and it seems clean and dry inside.
