[SOLVED] ENG Bar 15a Fuse keeps blowing
Nameless1298
My 15a ENG bar fuse keeps popping when I get on the gas. I know its most likely a short. I am getting 2 codes. P0102 (MAF circuit input low) and P0245 (Turbocbarger wastegate solenoid a low) I don't see and obvious damage to and wiring or to the grounds or anything up top. Any input is helpful. I should also say it's only happening when I accelerate harder than normal driving.
Already a thread on this that will likely point you in the right direction. Search, or check the similar threads section below.
I actually found out what happened. It got worse and couldn't make it home. One of the harnesses wasn't zipped up and was rubbing on the shift lever. It has rubbed through to bare wire. And everytime id shift to 4th gear it would blow. I thought it was just accelerating hard. But I was accelerating to to 4th gear.
