New to the forum, trying to find a particularly elusive problem.
Yesterday I changed the oil on my 1st Gen MS3 (2012 engine in it) and about 30 minutes later when I was merging onto the highway it lost power and started misfiring. Whenever I go past a certain throttle position it started misfiring and won't speed up and I lose all power.
Below are the engine codes I currently have:
-PCM
-P0300
-P0403
-P2006
-IC
-U2064
Previous owner did these mods:
- Custom 3" downpipe with 3" cut out (cut out is currently blocked off, haven't really looked at that at all)
- 3" full exhaust
- JBR 3" turbo inlet pipe
- Auto tech HPFP internals
- Damond oil restrictor bolt (no clue what this does)
- Cobb access port v3
- EGR delete
- VCTS delete
So far to try and diagnose it I've installed new NGK Iridium spark plugs (gapped at .027), new coil packs (with lithium grease), tested to make sure the coil packs were firing consistently, cleaned the MAF and MAP and made sure they were connected snugly, taken off the intercooler and checking all the couplers and pipes for leaks.
I can't find any problems with boost, I have some videos of it running and of the accessport if anyone needs information.
Please help lol, I'm at a loss and I have work in 12 hours.
-PCM
-P0300
-P0403
-P2006
-IC
-U2064
- 3" full exhaust
- EGR delete
- VCTS delete
