Turbooooh
ENGINE/DRIVABILITY
Mileage: 207,000 miles
Location/Alitutude: Missouri Ozarks
Concern: Engine will not idle, or occasionally will hang on with a very rough idle, then die; when rolling slow in 1st or 2nd gear, gas pedal is VERY touchy and causes the car to buck; Engine bogs/misfires? once turbo starts to spool (>5psi),
DTC's: PCM: 2177(fuel system too lean at off idle), P0571(cruise control/brake switch A circuit malfunction), P0403(egr deleted), IC: U2064
Modifications: Mazdaspeed Intake, 2"ish Turbo Inlet pipe, stock replacement turbo, Ebay Downpipe (12 years old and still in great shape!), Autotech HPFP, Aftermarket top-mount IC(unsure of brand), aftermarket BPV, Grimmspeed EBCS
ECU/Tuning Software: Cobb Accessport V3, tried 3 different basic tunes, including safemode with no difference
Tuner: n/a
Recent Repairs: Replaced rod bearings and rings on 4 pistons, deleted balance shaft anchor(!) and installed plug, reinstalled recently replaced timing parts (chain, VVT, tensioner, etc), new Autolite iridium spark plugs gapped to .028
Attempted these corrections: Cleaned intake flapper, MAF, and purge valve
Correction: Found untorqued intake bolts using spray and search method; torqued intake bolts and all is well!
Tuner: n/a
