So my '13 MS3 has had various intermittent EVAP CELs over the past year or so. P1450, one for gross leak and one other, I think. (Sorry, it's been a long time and I didn't write them down). P1450 is the only one that occurs recently. I've replaced the gas cap with a generic aftermarket and an OEM Mazda and that never seemed to do anything. Yes, I click the hell out of the gas cap when I tighten it after filling up. I've also tested the purge valve solenoid under the hood and it seems healthy.
The CEL's aren't really the issue though. They're just a minor nuisance that I clear out with my AP. The real problem is that fuel sprays back out of the filler neck when I'm trying to fill the tank. Here's the pertinent facts:
--The tank is always under 1/4. Never tried at other levels.
--This happens at all stations and regardless of what I do with the nozzle.
--Weather and temperature seem to be irrelevant.
--When I first remove the gas cap, nothing weird happens. I can hear a little bit of air moving.
--The first gallon or so will go normally at the whatever rate the nozzle is set on then the pump clicks off, I hear a gurgling and a pint or so of gas will spray out and run down the fender.
--The second gallon will usually do the same thing. The spraying out usually only happens twice.
--Filling the rest of the tank takes forever because I'll get a few tenths of a gallon in then the pump clicks off.
--If I pull the nozzle out and wait a few seconds, I can get maybe a half gallon in at one go before the pump clicks off.
What I'm really confused about is the source of sufficient pressure to blow so much gas all the way back up the neck and why it only happens a couple times when the tank is near empty. At this point I welcome any ideas or speculation because I don't know WTF is going on or how to troubleshoot this.
