The problem started when I found and fixed a small coolant leak on the turbo feed for my GTX3071. I had to remove TIP, battery, box etc to get to it. Once I got it all back together I am down to around spring pressure (19lbs) and not able to hit my load targets. The boost pressure is hit or miss now ranging from 17-20 psi max on a log.
Here are the things I have checked to see if it was the issue.
Boost leak test - no leaks
checked all EBCS lines - no tears or holes
Removed my ewg and tested it by pressurizing the bottom port - opens and closes correctly
Looked for exhaust leaks around turbo, mani, and dp - nothing
Checked turbo - no side to side or in out play
swapped BPV to a known working one - no changes
Uninstalled AP and reinstalled - no change
New map direct from tuner - no change
bypassed my ebcs (hooked pressure line straight to the bottom port on my wastegate - couldn't hit spring pressure (19psi spring)
Checked guardian angel operation and even bypassed it - no changes
I'm at a loss for why I can't even hit spring pressure. I'm thinking my wastegate is messed up but I can't wrap my head around the fact that its opening (screamer pipe) but only hitting around 17psi and way down on my load target.
Has anyone had a similar issue? Any help at this point would be awesome.
Oh my main mods are -
GTx3071 - ATP EWG hotside with Tial MVS
Fullrace mani
HTP3.5 Intake
Grimmspeed EBCS
V1 Guardian Angel
Devils own meth kit stg 1 (I have switched back to 93 only map for troubleshooting)
Turbosmart 50/50 BPV
Cobb FMIC
EDIT: thought I had narrowed it down to blown turbo. Have replaced CHRA with new Garrett one. Still same issues as before.
Fullrace mani
HTP3.5 Intake
Grimmspeed EBCS
V1 Guardian Angel
Cobb FMIC
