Front Axle replacement
Ivan
Hi all, im new to this forum. I am planning on replacing front axles due leak from the pto and play in left axle. My problem is that i cannot find anywhere the correct Seal #s for the replacement. The once i have found are for CX-7s (auto) and Mazdaspeed 3. If anyone has done this and they have fixed the leaking issue please help me out. Here is a list of the part numbers i have came up due my research, let me know if any of those are the correct ones. Thank you.
These are the Part#s i have came out with.
Axle seal - A601-27-238
Driver side (MS3/MS6)
Passenger side (MS3/MS6)
Tcase side oil seal - A601-27-397
(MS6)
go to jim ellis mazda's website. you should find what you need there
edit: sorry for double post...cleaned it up. work internet is acting up
driver's side is A60127238, passenger is A60227238.
I ordered mine from Edge Autosport and got em overnighted for my Trans install the day after.
