SlyFox1014
Vehicle Information.
2007 Mazdaspeed 3
169,XXX miles
Injen CAI
Turbosmart Kompact BOV
Corksport Racepipe
eBay "cat" back exhaust
Cobb Accessport with Stage 1+ OTS map
Car started and ran fine, had the second cat removed as I was replacing it with the racepipe and it was sitting in my shops parking lot while we waited. Car went in and had the valve cover gasket replaced with an OEM one, LT cv axle was replaced and the racepipe was installed. Now when the car starts it idles for about 5 seconds and dies. This was not an issue before these couple things were done. I bypasses the fuel pump resistor and no change. I have a new MAF sensor and connector pigtail coming just to cover that base but I am leaning towards the HPFP just going bad as a coincidence.
Looking for affirmation or if I should check anything else before replacing the pump.
ITFP holds pressure at 71psi with KOEO, we put a smoke machine on it to mkae sure we didn't have a vacuum leak and nothing.
2007 Mazdaspeed 3
169,XXX miles
Injen CAI
Corksport Racepipe
