Matt Dickey
Yeah to my knowledge over 180k and i checked thoroughly for boost leaks before i put the intake back on just to cover all bases before i started it for the first time with the new injectors. But ill check again. I had it tuned with the bad injectors and was fighting a slightly lean at WOT issue for a while and Will kept throwing fuel at it. So im assuming the injectors are just maybe way more efficient than the others so the ecu is pulling back on the fuel. And sorry those fuel trims i referred to are negative.
