Looked around a bit and can't find anything quite like what I am experiencing at the moment. A little while back my car was warming up, sputtered, and died. Couldn't get it to start afterwards. Engine would crank, start, and immediately die like it was starved of fuel or something.
After some diagnostics, at the recommendation of someone in a MS3 discord I'm a part of, I replaced my Fuel Pressure Sensor and the car now starts and will idle. The issue I'm running into now is my fuel pressure. During idle and once it's warmed up, it sits from 450-500. However during warmup, it never rises above 1050~ and as it tries to, a whistle-like noise can be heard. I pulled my relief valve and couldn't blow any air through it but ordered a new one just in case. Got the new one installed and I'm still having the same symptoms/issues. Is it common to order new ones that have already failed?
All fuses have been tested and aren't the issue. I haven't yet tested the resistor and I plan to do that soon, but from my understanding it seems like the pump is getting enough power to get the pressure to where it needs to be, it's just not holding it anywhere past 1050~.
I'm at a loss at this point. Thanks for any input or suggestions you guys might have.
