Bighern9999
Good evening everyone, I just bought a speed 6. Got it for 2k and loving it but the problems started coming out. So I have the standard oil consumption problem, also had a p0192 for fuel rail sensor and p0300. Changed out the sensor and code went away, I cleaned the EGR assembly and tube for good measiure. I changed the spark plugs, checked the coils but might replace them too. So the issue now I have a P0300 again, I removed the HPFP and cleaned it and installed back on. Code went away then the misfire came back. Now this happen above halfway or full throttle, almost feels as if the it's choking and not getting enough fuel. I'm trying to use this as a daily, unfortunately I don't have a Cobb access port or anything besides the generic scanner. This is what was collected from the freeze frame data when the DTC was triggered.
ECT (F) 177.8
calculated load 59.2%
STFT- 0%
LTFT- 0%
MAP- 52.6 (inHg)
Eng RPM- 4022 rpm
speed 34 mph
spark advance (7.0 degrees)
IAT (F)- 120.2
MAF (lb/min) 18.0
TPS- 42.7%
Fuel pressure 1280.7 psi
EGR command 0%
evaporator command 0%
It's been a while since I've been in the tuner community, this is my first turbo car too.
ECT (F) 177.8
STFT- 0%
LTFT- 0%
MAP- 52.6 (inHg)
Eng RPM- 4022 rpm
speed 34 mph
IAT (F)- 120.2
MAF (lb/min) 18.0
TPS- 42.7%
EGR command 0%
