eject0seat0cuz
I am working with Freektune to get my 91 tune squared away. On the second revision the BNR S4 was hitting 20psi no problemo. I switched tunes to the 3rd revision and can't get it over 13.5psi. I took some 3rd gear logs (attached) and then changed back to the 2nd revision and it is doing the same thing on that one now as well. I checked for boost leaks and didn't see anything but if you guys could check out the logs and point me in a direction I would be appreciative. I sent the logs to Justin and obviously haven't heard back yet, but I thought I would come here to get a jump on the troubleshooting process and give you guys something to chew on. Log 31 is the old revision when it was reaching 20psi (for reference). Let me know what you all think, no idea is a bad one because I am kind of stuck, thanks.
Mod List:
Grimmspeed EBCS
Bosch 3 Bar
Corksport Dual VTA BPV
BNRS4v2
Autotech HPFP
ETS TMIC
JBR 3.5in SRI
UR catless DP
Corksport TP
Mod List:
Grimmspeed EBCS
Bosch 3 Bar
BNRS4v2
Autotech HPFP
ETS TMIC
JBR 3.5in SRI
UR catless DP
Corksport TP
