Hi guys and gals!
I'm not new to the Mazdaspeed community, just new to this specific forum. I have a pretty heavily modded 2013 Mazdaspeed 3 that has been sort of an ongoing project for the last 2 years and I will be making some pretty big changes in the near future. I have a company vehicle now, so this isn't a DD anymore, which allows me to have a bit more flexibility and have some more fun with it. My goal is to squeeze every last bit of power I can out of the stock block til it dies, then build a new block and crank it way up.
Current mods:
Cobb AP V3
Corksport HPFP Internals
Corksport 3" Intake/TIP
Custom PnP IM w/VTCS & EGR Delete
Bosch 3 Bar Map Sensor
Cobb 3" SS Turbo Back Exhaust
BNR S4 v2 Turbo
Corksport MZR BPV
Corksport OCC
cp-e Delta Core FMIC/Piping
cp-e xFlex Stage 2 RMM
KW v3 Coilovers
JBR Front & Rear Anti-Sway bars
SPC Rear Camber Arms
Moog End Links
Stoptech Rotors/Pads/Braided SS Lines
Corksport Mid-Chassis Brace
Misc Body Mods/Visual upgrades
More stuff I'm probably just forgetting right now...
Upcoming Mods/Swaps:
JBR Tru-3.5 Wide Path Intake (replacing Corksport 3")
JMF v2 PI Intake Manifold (replacing PnP Stock IM)
Custom Port Injection Setup (aux fueling)
Full Race Turbo Manifold (moar flow)
Cobb XLE BPV (works better with my setup)
Corksport Injector Seals (necessary)
Damond PCV Plate & Stage 3 OCC Setup (crank case pressure)
Whiteline Suspension Bushings/Bump Steer Kit (stability)
Corksport Aluminum Skid Plate (because racecar)
cp-e xFlex PMM & TMM (wheel hop/torque steer)
Aerodynamic mods (stability)
Several other supporting bits and pieces...
I look forward to sharing my experience and knowledge, as well as learning from people who have already experienced much of what I'm about to go through.
Thanks!
Jason
Current mods:
Cobb AP V3
BNR S4 v2 Turbo
Corksport MZR BPV
Corksport OCC
KW v3 Coilovers
Moog End Links
Thanks!
Jason
