Good day to all. I have a Mazdaspeed6 which has been giving me some issues. One was a stuttering problem at idle and accelerating. I changed all spark plug and coil pack. and the stuttering became much more noticeable that it does not have much power at all, as if it is only firing on 3 cylinders. I upgraded the internal tank fuel pump, cleaned and change all )-rings on the HPFP, changed the pressure valve and sensor on the fuel rail. And still no change in the stuttering. Next thing I plan on doing is getting injectors cleaned. But before I do that i decided to run an Autel diagnostic on my car. And this is what came up. Can anyone help or point me in the right direction for this.
