This is going to be the start of a thread on how to perform diagnostics for all general automotive concerns.
I will try to break down issues by section. New threads will be made for each type of concern and the different ways on how to perform the test procedures.
The first subject will be on electronics/electricity. This is because modern cars rely so much on proper electrical operations many overlook performing the right steps and throw parts at their cars trying to fix an issue that may not be part related.
How does electricity work? Much like water flows. To properly diagnose a concern you must understand the fundamentals behind how it operates. Think of a battery as your well. Voltage is the total amount of electricity (water) available. Resistance is how much of a kink is in the wire (hose) and Amperage is how fast/how much the electricity can flow.
Here are some simple formulas for calculating Voltage, Amperage, and Resistance.
Voltage = Amperage x Resistance
Amperage = Voltage / Resistance
Resistance = Voltage / Amperage
You may not need to use formulas as many people don't when performing the diagnostics, however this is electrical 101 and it is important to have them.
A note about Amperage
Just like too much water pressure in a hose can cause swelling, too small of a wire can cause excessive heat when a lot of amperage is being pushed through it. This can be seen with high load components such as adding a cooling fan but selecting a wire not large enough to carry the current. The end result will be the fan will work, but the wire gets hot over time causing the wire to burn up and in a worst case scenario, a fire. When adding aftermarket electrical components please take this into consideration.
Next step is to understand the tests to perform. What they are, what they test for, and how to perform them. I will update the thread later on with specifics such as checking voltage drop, short to ground, short to voltage and so on.
As for the proper tools for testing electrical systems please have the following:
A good digital multimeter such as Fluke, Snap On, Matco etc. Having one with a MIN/MAX feature can be very helpful when performing tests on systems that only operate for a split second when the car is initially keyed on.
A regular headlamp bulb NOT LED and socket. a 9004 is what I use for load testing. The socket with leads can be had for about 6 dollars and a bulb for about 10. Add some pins to the end of it or solder the stripped wire flat to allow it to be inserted into connectors. Polarity doesn't matter as current will flow through the bulb either way.
Power Probe. Probably the best tool you can use. These have digital displays, the ability to put power through a circuit or to ground a component for testing. Be careful with these because if you apply power to an ECU or other circuit board electronic on the wrong circuit you can burn the component up.
https://www.napaonline.com/en/p/BK_...bV36-BtNpLOHWcxZ0UbrJ_R9byNY60saAnGxEALw_wcB&
TO PREVENT DAMAGE TO CONNECTORS BUY THESE KITS!
These will allow you to properly check terminal tension and prevent spreading pins by shoving meter leads into terminals. I use these on all my electrical diagnostics as they connect right into my multimeter and power probe tool. Buy both of these and you will be able to properly probe every terminal out so far.
