How to: RaiderFab Bumper Fitment Fix Gen1 MS3 Fenderwell Only-Option1
Youngwonder
****If you have ANY questions about the instructions, do not proceed until you contact RaiderFab! There is a chat option on raiderfab.com, email raiderfabusa@gmail.com, or message on social media, PRIOR to drilling holes or making any modification which cannot be undone.****.
I am a noob but this is the way I put the quick latch in and it seem to work out pretty well. It took about 30 min taking my time. I already bought the latch and didn't get the springs. I'm sure they are more convenient but I don't think it it's a big loss of you don't have them.
This is what I did prior. Gorilla tape held up well. Downside now i have to clean the goo. The tab broke and the clips in the front of the bumper doesn't hold either.
I first removed the wheel and got the fender lining out of the way.
I used the preexisting screw where the tab broke. The bracket allows you to be able to adjust the depth of the bracket. I set mine in the middle. *Note* see the space between the fender and the bracket? I'll bring that up again later.
I put the pin in the middle of the bracket I put it on short (not pictured).
I took a piece of clay bar on the pin and placed the bumper into position.
There you have the perfect placement of the pin. I was satisfied with the location. I made sure there was enough space for the latch retaining nut and the latch will not be hanging off the side of the bumper.
Take a center punch and punch the middle of the clay. That's what I'm pointing to.
Here is where the fun begins. I took a snap bit and drilled where I did the punch.IMG_20160709_140246155.jpg
I lined it up to see if I was on the right track. Not perfect but very close.
I traced the latch just to make sure I don't drill a hole too big and also keep my alignment so I wouldn't veer off too much.
I decided to measure it to see what bit would work best. I found that the bit I used was just a tad smaller than the latch. I did that on purpose. I made the hole bigger I aligned the bumper again to see if the pin was in the middle of the hole.
Once the hole was big enough I put the retaining nut on the latch, put the pin at the desired length, and latched the bumper. As I said before the clips in the front doesn't latch but the bumper holds up pretty well.
I went ahead and did the other side. Since that was ok I cut open the tab. The note from earlier when I did the other side there was no space between the bracket and the fender. I put rubber o-rings to create some space. Pictured with no spacing.
Here is the finished product.
IMG_20160710_075640164_HDR.jpg IMG_20160710_075649251_HDR.jpg IMG_20160710_075702637_HDR.jpgIMG_20160710_121317392_HDR.jpg IMG_20160710_121336057_HDR.jpg IMG_20160710_121348305_HDR.jpg IMG_20160710_121357588_HDR.jpg
Overall it was simple to install. Remember start the hole small and work your way up. Make sure everything lines up the whole process.
AWESOME WRITE-UP!!
Glad they worked! All you need is the pic of the finished install. Ha!
I think you would benefit from one up front too.
Nice write up. I had the issue with the bracket touching as well, but rather than trim more bumper, I shifted the bracket back and extended the stud out further. A spacer under it works as well looks like.
It really wasn't hard to install. I panicked a little when the bumper tab didn't slip over the bracket.
