How to rear "big brake conversion" for the broke guys
roli1206
You give your last penny for a sick front brake setup but now you are broke but at the same time you look at your car and you see that your rear brakes look like they shrunk ..... easy solution for this (as some maybe already know) the mazda 5 cr19 has 300mm rear disks with the same exact measurments as the speed 3 discs except the diameter
what you need ...
C2Y6-26-28XA ......brake caliper bracket
mazda 5 discs ..... done
pads are still the same size
istallation .... pnp
top tipp if you get your discs at mtec brakes you can choose drilled/dimpled/slotted/g-hook brake discs !
pro's
it looks better + of course they got better bite and because of the more material better heat capabilities
cons
slightly more rotating mass
i haven't experienced anything bad until now and i did that conversion a growing number of speeds
