Just got the car back on the road. Timing service complete. RMM installed. Rear springs replaced. Lower control arms and sway bar links replaced on the front. Thats the good part. Now the bad. Entire exhaust needs to be replaced. Main O2 sensor is dead. CEL shows lean at idle. Drove great for the first 30 minutes. Now I think the clutch is slipping. 3 times it felt like it wanted to stall out in 1st and 2nd gear (from start and downshift). Also appears that rear driver side is leaning (only tire that rubs). Also needs an alignment. I named this car correctly, its clearly on a mission to trap all of my monies.
