Nstalker12
Alright so long story but I’ll try and make it as short as possible so i have been having issues off and on for the last 4 months it stems from the time i was driving my car normally to taco bell to slam some tacos with the boys and when we were in the drive through the car suddenly bogged down and died we had to push it into the parking lot and it was about 30 minutes later i tried turning it over it finally cranked back over and turned on keep in mind i tried turning it over for that 30 minutes and it just cranked and wouldn't start. so i finally got it home and the next morning i tried turning it over again.. no luck so i did research and tried to resolve the issues and replaced lots of parts such as spark plugs gapped them to .26 and new coils, new cam and crankshaft sensor and all of that good stuff and cleaned injectors and finally after that she started running good for a little bit the she ended up not wanting to start again so i did more research and went through the forums and found out possibly MAF sensor issues so replaced that with o Reilly's special it drove again for a little bit but wouldn't start.. then i read that o Reilly's maf sensors are trash so got an OEM Mazda one. still not working, checked spark, and did more research and possibly narrowed it down to fueling or electrical. So i checked relays fuses all good check wires to see any issues check spill valve on top of HPFP and cleaned it and checked fuel pump ballast resistor and all seems good I think idk the best way to check if the ballast resistor or spill valve are messed.. now I'm at a loss i also checked to see if throttle body is opening up and it was.. I'm at a complete loss and i just want to be able to drive my car with no issues i plan on checking, pressure release valve i think its called but would that cause my car not to run? But then I’m gonna take a deeper look at HPFP check fuel lines then finally check in tank fuel pump but I'm not 100% sure and I'm not an expert by any means so i just was seeing if you guys could help. btw its a first gen with HPFP internals. EGR delete, intake, downpipe, BOV and just recently put on a FMIC. it has been sitting in my drive way for about 3 weeks now and its been working off and on for like the past 4 months
