So I broke the nipple on the air intake resonator pipe (part # L3K913230). It's the nipple that corresponds to the wastegate control solenoid valve sensor and hose. Kinda important! I broke the sensor end once too...ugh! I always forget about those little hoses.
Maxdaspeed3 and CX-9 resonators are not the same. There is slight difference in mounting points.
Anyway, this JB WELD Plastic Weld seems to have worked. It seems to be sticking well. I hope its holds up under the heat. (SEE BELOW FOR BETTER OPTION USING BRASS BARB)
You need to clean the surfaces with alcohol and the scuff them up with a small file or emory cloth or whatever.
