2010 MS3 no power mods
Stock HPFP and COBB OTS stage 0 map
115k miles
Valve cleaning, injector cleaning, and Overspeed seals done at 100k and timing chain done at 95k. Only have 91 octane available.
I fixed a few boost leaks that were causing me to have a little over 6 KR and its down to just under 3 KR at WOT. Trying to move it to close to 0 if not zero.
Please. Read. The. Files.
Only 1 person told me I may have some leaks because my STFT/LTFT were both maxing out -/+ and the AFR was in the 9's and everyone else told me my KR was that high simply because it's COBB stage 0 map and the one guy was right. Hoping someone else or the same guy can see my readings and tell me where else to look for problems. I didn't find any other leaks, but I am willing to bring it to a shop for a smoke test if recommended and makes sense at this point. My STFT/LTFT both are close to zero when cruising compared to before but the AFR dropped to 8 at one point in an unrecorded pull post fix.
Third gear:
115k miles
Third gear:
Template public:_media_site_embed_googledrive not found. Try rebuilding or reinstalling the s9e/MediaSites add-on.
Fourth gear:Template public:_media_site_embed_googledrive not found. Try rebuilding or reinstalling the s9e/MediaSites add-on.
