andrew_ms3
Hey guys I've been trying to figure out why my AFRs dip to 13.5 and raise to 15.5 during light throttle inputs in 1st-3rd gear. The moments these dips and raises occur are very brief and the AFRs quickly return to 14.7. Part throttle LTFTs are always under +5 and idle LTFTs always under +9 (changes with AC on or off). They don't fluctuate like this while at a constant RPM at higher cruising speeds. I've loosened and retightened boost tubes, CS short ram, and the stock TIP to ensure I have no boost leaks. I have cleaned the MAF sensor numerous times as well as the throttle body. I did notice that there is a knick on one of the O2 sensor wires and was wondering if this was causing my issues? Only other guess I have is that I do not have an air straightener which could be causing the fluctuations. Before I start spending money on replacement parts I would like you guys input. Only mods are CS short ram, HPFP internals, and a Hypertech tune.
